Question Closed
Why doesn't my volume work anymore?
After rebooting my computer the last time I get no sound anymore. When i press the volume up button I get the standard view of the volume at full but a small circle with a line through it on the bottom which has never been there before. Same with anytime I try to move the volume or mute it. What can I do to fix this??
Add a comment
1 Answer
Click on the apple at the upper right of your screen, then go to about this mac. Click on more info, then under hardware you should see audio, click on it and see if it gives you info about the hardware. If it does not that means your system does not see the audio device and it is probably faulty.
1 Comment:
I checked and there is information there, although it says "mute" under all categories with no playthrough. How do I turn off the master mute?
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,995
