0
Score
Asked
Volume indicator indicates bacwards
Volume indicator starts at 60 (no volume) and counts backwards to 1 (full volume) What do I do to fix the problem? Or is there some good reason as to why the volume is indicated this way?
0
Score
David Hodson
13.5k
Answered
From the units I've seen, home receivers are just set up that way. I'm sure someone will have a better answer after me. If you look carefully, it will probably be a negative 60, rather than positive. That's the experience I've had, anyway.
Basically, each decibal is a ten-fold increase in sound. If no sound was labeled as zero, ten times that would still be zero. So the loudest volume is used as a reference instead.
