Doesn't seem to be getting water?
All of a sudden my dishwasher doesn't wash. At the end of the wash and dry the soap is lying on the bottom. Is this something easily repairable?
Water-inlet valve
The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Good answer +
check the float in the dish washer. sometimes spoon or other stuf fall through racks and fall under the float raising it, or some times floats gets stuck in up position which prevents water from filling the DW
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,843
