3
Score
dllamond
37
Asked
iPhone 3G Glass/Digiter Replacement: Screen Now Black
Ok, so I replaced the glass and put it back together only to get a black screen. I took it back apart and I think the #3 ribbon was pulled out but I'm not certain. The whole time, the phone functions (iTunes sync, mute button toggle causes vibration).
So here's what I've done with no success:
1. Changed back to the old (cracked) screen
2. Attempted hard reset (power + home). I'm not certain the home button was working at this point.
3. Discharged battery, recharged, hard reset
4. Discharged, re-seat cables 1, 2, 3. Charge. Hard Reset
5. Discharged. Pull logic board from battery to allow full power down. Reassemble. Charge. Startup. Hard reset.
Its sitting on the wall charger now in some hope that it needs a full charge for a proper hard reset.
Any ideas?! Help would be greatly appreciated as Google's not giving me much at this point.
Oh, I've tried to swipe the unlock button several times, but I've never heard the unlock sound so I'm pretty sure both the LCD and the digitizer aren't being recognized.
Thanks in advance....
Lucas
7
Score
pollytinto
29.8k
Answered
Accepted Answer
if the screen is black completely ie no faint home screen, and you've tried reseating the connector (no 1) with no luck then it is either the wrong screen ( i had a new lcd for a 3g which didn't fit-check the model number is for the screen you bought) or you have broken another lcd.
5
Score
Answered
I have had this problem several times on the same phone, I let it sit for 2-3 days with the logic board out of the phone. I found on my last install when my customers power switch would not work properly:
1. Disconnect the #4 cable and tilt the motherboard up so it does not contact the battery.
2. Connect all the connectors for the face.
3. set the motherboard down on the battery.
4. Connect the #4 cable and the LCD worked properly.
Shut down the phone properly and reinstall the motherboard screws
Good luck
I've created an account just to let others know that Steve's solution up above did it for me. It appears indeed that the iPhone gets "confused" when power is still running through the circuits and the screen/digitize
+1 for Steve! I figured I must have bent the connector the wrong way, and I was not happy. (I had just finished replacing the back, dock connector, home button, and camera). Everything was working perfectly except the home button wasn't aligned properly, and I must have forgotten to turn it off when I opened it up to adjust it. I lifted the motherboard from the battery, and now everything is working great!
2
Score
chris eklund
25
Answered
plug it in to itunes and restore that worked for me
same problem for me too... i replaced the actual LCD screen and the glass digitizer,when i replaced the glass the original LCD worked fine except for the black spots that i caused (reason for replacing) but when i tried to replace the actual LCD the screen is now black though i still hear the sounds. restoring had no help to me so im open and begging for new ideas!!! UPDATE: my screen does light up but its still black, so something is being recognized but it wont show anything but a lit up black screen
Score
jcmetais
133
Answered
Score
Answered
I've got the same issue. I've restored the phone and it completes it goes into DFU mode and it vibrates at times but there's no picture. The phone LCD is completely dead. I've taken it apart disconnected and reconnected the wires and I've had no luck.
I did notice while I was in the phone that the #4 conector wasn't connected after I did a complete restore to custom firmware. Now I don't think it came loose when I popped the screen loose so this has me interested.
Score
George
13
Answered
when you take apart an iPhone 3G/3Gs... do not forget to turn it off before you take it apart. it usually in a way "tricks" your motherboard into thinking your LCD is on when it is not, and and when it is all together your LCD is black. so don't forget to turn it off before you start the repair..
0
Score
nahman
Answered
+1 for steve method... kind of.
I was replacing the LCD and I had it successfully turn on once, but then turned it off (I thought) and disconnected everything because the glass/digitizer was popping up. repaired that and hooked everything back up but nothing was showing up on screen.
tried unhooking and re-hooking everything up to no avail.
then unhooked #4, unscrewed all motherboard screws, lifted it from the battery, hooked up the screen, hooked up 4 -- STILL NOTHING!
so, I unhooked the screen again, did the screws back up. sat there perplexed. tried hooking the screen up one more time, and voila! turns on for some reason? Maybe the battery was disconnected long enough to shut the system down and let the last screen hook up take? dunno...
phone is working again!
0
Score
cherise
Answered
Okay so today, when replacing the Glass screen, i followed the instructions to a t and did it slowly, now when i put it back together everything was connected. and it plugged in screen is black and an error message come up in itunes, have i buggered the lcd screen.
0
Score
nic
Answered
0
Score
Answered
Thank you very much this was extremely helpful! I had the same issue with my iPad 2. I replaced he digitizer and my LCD seemed to stop working after I replaced the cracked screen. I assumed that I had cracked the LCD during the removal of the screen. I purchased a new LCD but it still did not work. After reading your answers, I realized what the problem was. I turned off the iPad and then turned it back on and vuala it worked just fine.
0
Score
edcimo
Answered
0
Score
sharki
Answered
hi all,
im having the same issues and after doing all that you have said its still not resolving. the phone works bang on but no display just a blank screen with the back light lit.
0
Score
MARC
Answered
had same as above problem (black screen on reassembly) after replacing the complete 3 part lcd screen, digitizer / button assembly, i got mine working by holding both the on/off button and the front screen button on or down together, the apple logo came in view and the problem seems to be rectified, leaving it on charge over night and all so far seems ok, seems that i did not power off properly as other people mention but, i couldn't due to the damage sustained with it being thrown at me in a row with the enemy at home!, lol.
0
Score
qnc
Answered
To Steve Parkhurst
You are my hero. I have replaced at least 20 digitizer screen/glass combinations. Mine once, wife once and everybody I know that has an iPhone that is scared to do it.
This stumped me and I was about to just give up because I can do it with my eyes shut. Thanks for the great answer.
I joined just to say thank you and give a rep.
0
Score
Answered
I have had exactly the same problem. You had any luck yet? Thanks
Chris Bowers,
Exact same problem. ugh..
Garret Bluhm,
