Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
Question Closed
I can't access my iPhone 3G arrow will not swipe to unlock
I purchase the front panel screen kit and replace the screen with no problem, but I am still getting the same problem. The touch pad is not working. I can not slide the arrow to unlock the iPhone. Can someone please help.
Add a comment
hy same problem you figure anything out?
Add a comment
faulty digitizer no doubt
Add a comment
Replacing the screen-glass and digitizer will fix it. I have done a number of these. Easy way is to replace the glass digitizer is using one part module of glass with digitizer bonded. Be careful handling the LCD. Do not bend to force it when you swap to new glass and digitizer. You can get mysterious areas on them (LCD) that look like circular burn marks from mishandling=shot. You have to scrape off the old glass and reuse the bezel by heating with heat gun or even blow dryer to loosen the glue. New unit has tape to adhere to bezel. You can use a pre-assembled ready to go front/bezel with the home button and just add the LCD except many/most of the aftermarket 3rd party home buttons feel cheap or even loose and not of the same quality.
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 2,574
