13
Score
QEII Student IT
3.5k
Asked
How dangerous is working on a CRT display?
I've heard that taking apart a CRT can be dangerous so before I go ahead on the eMac teardown I plan to create for ifixit; how dangerous?
19
Score
David Iwanicki
2.7k
Answered
Accepted Answer
A CRT can hold several THOUSAND volts of electricity in its flyback circuitry. If you do not have the necessary experience and tools to properly discharge and make safe a CRT, you should not even take the plastic cover off. There is also the chance of physically damaging the fragile neck of the CRT, leading to a violent implosion as the vacuum is released. This could spray poisonous, phosphor-covered shards of glass all over the room.
Mac Geniuses must pass the CRT safety section of the certification exam with a 100% score every year - it's that serious of a safety issue.
Also, don't think a CRT which has been powered off for a long period of time will be safe - the CRT will slowly continue to build static electricity just due to the Earth's rotation and magnetic fields.
Peachpit Press has an excellent excerpt from its Training Series books discussing CRT safety here:
http://www.peachpit.com/articles/article...
Servicing a CRT-based Macintosh should be left to the professionals due to the inherent dangers. I avoid them as much as possible, even though I am thoroughly trained, with decades of experience working on CRT-based computers, monitors, and test equipment.
You're absolutely right, but it is possible to do it on your own. You'd just have to build your own CRT discharge tool out of a coathanger, rubber handle, and a grounding wire. The 'leave one hand behind your back' suggestion is standard practice for dealing with high voltages.
Does that apply to televisions as well ? A friend of my dad who knew a bit about them used to tinker with them and I'm 200% sure he hasn't even heard of any certification exam.
Anky,
7
Score
Ptr702
557
Answered
Working at an authorized apple repair center a few years back, I was discharging an eMac CRT, as I was prying off the cap the alligator clip popped off the ground and made contact. I was blown black into my other bench, hand smoking... Worst pain i have ever felt, I think I even peed myself. I can still remember the feeling today. So just be very very very very careful when you discharge it, or if you don't feel comfortable, take it to a tv repair shop and let the pros take the risk... I no longer discharge the emacs, I leave it up to my other techs.
3
Score
rj713
31k
Answered
I found Davids response very useful having serviced crts as a Navy ET for more than 20 yrs and highly recommend paying close attention to the article. The life you save may be your own. I would also caution early iMacs also have crts. I have repaired both practicing safety measures in Davids article. I would strongly recommend someone not trained to handle crts to avoid them if possible.
3
Score
cbsimkins
37
Answered
A CRT, especially older ones, can act as a capacitor. That means that if you discharge the tube at the anode, it may still build up a charge over time and so you should always keep a ground attached to drain the charge. Older tubes tend to not discharge the entire charge initially and after a while the charge returns to dangerous levels. Working on one is better left to trained technicians.
3
Score
pnauta
37
Answered
I agree with the cautions above. The bigger the screen (distance between the cathode and anode) the higher the voltage, which can be 25 000 volts or higher. Voltage does not kill, but current. The higher the voltage, the larger the current that will flow through your body and affect it. So, take extreme care. I had years of experience, but was always on edge when working on the high voltage circuit of CRT's.
Implosion is not that likely: put the viewing side of the CRT on a stack of towels, you'll be OK. These CRT's have to be tested before they get to be put in front of anyone's eyes, and are designed for really low pressures (vacuum). Just don't apply any uneven pressure, and stay away of the neck because that's the weak part.
As with all devices, disconnect from power source as a first step.
There's a cable with a rubber plug or shield on top which is the culprit. It keeps it's high voltage because there's a whole array of diodes and capacitors to get the electrons going the right way. The diodes keep current going in one way, the capacitors work like batteries. This cascade achieves a high voltage using an alternating voltage, and it requires extra circuitry and a risk of failure to make it discharge when the set is powered off. There's little current needed to illuminate the screen, but as it takes some time for your CRT to actually light up, you can figure there's a lot of electrons just waiting to take a route through your body.
We used to disconnect the rubber plug on top (anode) by using two long screw drivers with good isolated handles. As extra, wear rubber gloves. One would touch the metal frame, one would be used to pry undert the plug, then cross these two metal rods to short out. Another method would be to take a wire with crocodile clips and connect it to the frame on the one side and the screw driver on the other end. Pliers can be used to press together the metal clips under the rubber shield, when at least one side can be pryed loose, it will come off. You should always try a second discharge as a final check.
2
Score
QEII Student IT
3.5k
Answered
Actually, I think I'll just leave it to someone else to do a teardown, thanks for the answers!
I partially agree with you. Yes, it would be foolish to try yourself. NO, you should not leave it for someone else, there are many good reasons documented here that tell us there should never, ever be a teardown done on a CRT. It's just NOT A DIY DEVICE!
2
Score
mac605
97
Answered
I was able to replace disks and CDs in a few eMacs, without discharging (Yes, I know, formally it was not the smartest idea)
My remarks:
1. eMacs (especially older ie 700MHz) were Big PITA to disassemble
2. I followed Apple Service Manuals for those models - don't even thing about disassembling eMacs without them (or iFixit guides ;)
3. I tried keep as far as possible from CRT (it was not so hard after all - after I removed cover, disconnected Power button (another PITA), and then disconnected 2 or 3 cables around CRT I have to unplug, I have to concentrate on the bottom of eMac, where logic board/CD (yeah, there were models with CD-ROM drive only). Another PITA.
4. CRT was integrated with front cover, and it looks as really Non-User-Servicable-Part
2
Score
Brian
1.8k
Answered
Just to add to all this, a family member who did repair work for over 20 yrs, and a person that does not exaggerate this kind of thing witnessed a CRT implode and put a hole in a basement CMU wall. Someone hit the tip/neck.
This was for a TV im sure, since it was a long time ago. The implosion is of such force everything goes in opposite directions just like a bomb, just with negative pressure from vacuum and nasty gasses. Once of the few electronic devices that can really hurt or kill you in more then one way.
Boiler systems can do this as well, usually only causing damage to internal components. If your working on taking a boiler off line and don't vent it, you can create some really bad negative pressure. its enough pressure to suck a man threw a hatch doing maintenance without follow the SOP. (resulting in death). It was a big boiler.
Safety tech is good now, but isn't enough to completely eliminate human error, just like fixing one of these older models, a simple mistake can result in craziness, not worth it to me fixing such an older computer when I could pick up a working powerbook etc for approx. $100
2
Score
rickwag
25
Answered
I worked on a lot of CRT screens back in the 80’s. That rubber cap on the back of the CRT is where the voltage from the fly back transformer comes in. WARNING: THIS VOLTAGE IS HIGH ENOUGH TO REACH OUT AND TOUCH YOU! Do not try to measure this voltage with a standard multi-meter; you have to have a special hi-voltage probe, which is long and insulated. That extremely hi voltage is needed to push the electron stream across the vacuum space in the CRT; I have seen in excess of 40KV on some systems. We used to use a long flat blade screwdriver with a ground cable attached. Push the screwdriver tip under the edge of the rubber cup, you may see a spark. Then it would be discharged. If you are disposing the CRT it should have the vacuum pressure released. To release the pressure there is a metal connector under the rubber cup. Once the CRT has been discharged, disconnect the connector under the rubber cup. You will see the little metal connector nub underneath. You can cut that with diagonal cutters and you will hear the vacuum hiss; that is air rushing in the CRT tube. After that you can safely break the back of the CRT tube if that is your plan.
2
Score
teddyotool
37
Answered
I agree totally with the answers on here,As a television engineer i worked on crt's in the early years and believe me! they can pack a punch even after discharge as they do built up static,i still have scars where they arced across to my hands and burned little pin holes in them! So i would advise you to leave it up to a professional.
Teddy.
2
Score
erik Wanberg
25
Answered
Discharging CRTs is a relatively simple process, the concept is no different than what occurs when you see a spark from static electricity which has been stored in your body when you touch grounded metal. The key difference is the charge. The CRT stores thousands of volts when turned on and uses this high voltage store to supply the required energy for picture display and continually replenishes it, but when the tv is off normally there is a slow discharge and although a charge can be present in CRTs even if they haven't been used for some time, this usually is not a significant amount compared to the extremely high voltage when turned on. However, it can s be enough to take precautions to avoid. The potential lethality is overexaggerated and it should be reassuring to remember that though the voltage is extremely high, it is current that is dangerous. High voltage contact tends to to travel across the skin to ground without touching organs, and if discharged properly there is little chance of shock. I highly recommend a large flathead with a hefty insulated handle and a ground wire with alligator clips to connect the screwdriver to a working ground in an outlet (don't use metal case or other ground as cir uitboard damage can occur) and rubber gloves are not a bad idea but just in case of accidental shock one hand behind the back reduces risk of electrical path near the heart. Insert screwdriver carefully under rubber anode seal to discharge, a second time is not a bad protection, and that's it. Dozens of discharges with 0 incidents. One word of advice, only discharge when absolutely necessary. The potential damage to circuitboards, the glass under the rubber seal, yourself, etc. Is great enough to avoid unless there is a clear need.
Good luck, and remember that the CRT anode is preferable to a high current such as might be hiding in a capacitor or it's connecting leads. And tube implosion is not common, but do not forget to use care especially when picking one up because though not likely since the glass can handle more than a thousand pounds and not break, that doesn't mean it can't happen and I would rather grab a charged CRT anode than have a tube implode
Score
machead3
8.8k
Answered
Score
imran
13
Answered
Score
jackhilby
13
Answered
You must discharge the yolk but i agree if your new at it,DONT TRY IT
YOU can and Might KILL Yourself, if you must try to save your life you need thick strand wire thats heavely insolated ,ex. jumper cables (car jumper cables) and a true earth ground, best bet solid copper pipe directly pushed into your yard about 3 feet,and an electricians standard high voltage screw driver you can tell them by the rubber coating goes all the way to the tip well abot 1 inch, connect jumper cable clamp to the non insulated part of the screw driver and the other clamp on the copper rod you buried 3 feet in the ground,you cannot touch any part of the plain metal ,take the tip of the screw driver and slide it carfully under the suction cup on the tube aim towards the center
of the cup to were the anode is untill your hear a snap and a big blue spark.you could however realistically connect the cable clamp to the unpainted part of the monitor (CRT) frame and do the same thing,but to be safe go with the copper rod.
Score
altaf
25
Answered
Score
mbear
13
Answered
Yes, a CRT can kill you with the electrical charge it carries.
And yes, older TV sets DO use CRTs, so you can kill yourself working on them as well.
So don't do it. Pay someone else (who has all the correct equipment and health insurance) to do it.
There's no shame in asking for help. After all, Superman has the Justice League to help him out when he needs it.
Let me say it this way: Any repair procedure that advises you to only use one hand and keep the other behind your back so you don't complete a circuit across your heart is something you really don't want to mess with, IMHO.
Score
nicksmacan
9.9k
Answered
Avoid it i'm no apple techie but I work on eMac computers with friends and I hurt myself VERY BADLY(emphasis on very) so don't let them or buy a iMac(the CRT is separate from the memory and HDD and motherboard) your choice but in my opnion get a G4 iMac if you can and i'm not kidding look at the others and youll see why i say this
Score
Marko
13
Answered
W O W guys... I was about to try to disassemble an Apple CRT studio display and looking for an "how to" guide but was totally not aware of these risks... I wanted to make an aquarium from the casing but will think twice now... Thanks!
0
Score
Answered
Grounding it to a wall outlet does nothing; there is a grayish-black coating on the outside bell of the CRT (called Aquadag) and you will notice some type of metal spring or finger touching it - THIS is what you want to ground the wire to.
But even more important the CRT is made of glass and it contains an extremely high vacuum. If it breaks it will implode and glass will go flying everywhere. I strongly recommend at least wearing safety glasses before handling it.
I have found theat the best way to ground a tube it to connect a jumper cable to a flathead screwdriver (Insulated) to the ground prong of a wall outlet, then slipping the screwdriver under the rubber cover (Holding the screwdriver by the insulated handle) and that should safely discharge it. I have done this to my G3 iMac multiple times, yet the procdure is standard.
Chris Green,
This is a nice place for the High Voltage tag...
Dave,
