Score
Avatar
drkmanx
13
Asked
Testing parts after water damage
History
Hey all. I recently came into possession of a water damaged macbook. It was my cousins and he gave it to me to either try and fix or sell for parts. How do you guys go about testing the components to see what is salvageable and what is not? I have a macbook pro, would any of the parts be testable in there?
Im thinking maybe the memory and hard drive would be easiest. Does this carry any risk if the parts are shorted? id like to narrow things down and if its just a logic board i may repair and sell it or just sell as a fixer needing logic board.
Ive disassembled it but this is not a new spill and the unit has been sitting for some time, so I cannot really see anything wrong. Thanks.
Edited by
Alright, I fully disassembled it and i have found some residue on the logic board and some other parts. is washing in denatured alcohol worth doing? best guess would be to try that and reassemble, then decide if im buying parts or selling
drkmanx,
Post Answer
2
Score
Avatar
rdklinc
15.3k
Answered
PermalinkHistory
Aside from boards completely fried by liquid, I'd say the next most common liquid-damaged component is memory. Definitely pull the memory from the bad machine, and try your MacBook Pro's known-good memory. Using it for testing shouldn't hurt it. Try one module in one slot with the other empty, and then move the single module to the other slot if that doesn't work. This method of testing reveals if a slot is bad. I've had at least a dozen MacBooks work fine after just the memory was replaced. And usually, the damaged memory works again too if rubbing alcohol is swabbed over the corroded parts, which are usually sort of a crusty white on the memory module. I'd use q-tips and rubbing alcohol on any part of the MacBook which appears to be corroded.
Sure, you can use your Pro's hard drive for testing, but actually you should probably just pull the MacBook's drive while you're testing the machine, because for the most part it's not necessary that a hard drive be installed at all. If you ever get to the point where it chimes, the screen lights up, and you have a blinking question mark, then you can start to worry about the hard drive, but until then it's not necessary to have it in there.
Definitely try to reset the PMU...sometimes that "brings to life" dead machines. Good luck!
Edited by
The memory might not be compatible, might need to check that.
rab777hp,
If he's got an aluminum Pro it will work, but unibodies as far as I know use DDR3, so not in that case. Good catch.
rdklinc,
my mbp is alu non unibody, its a core duo
drkmanx,
Cool, the memory will work for testing then!
rdklinc,
alright. there is some white residue on the mainboard and a few other places... what is the proper way to clean that? also is there any way to test the monitor? what connection is the hard drive? its been a while since ive done any of this stuff so im not even sure what is standard right now.. but i would like to get an enclosure for other testing purposes so it would be good to have.
drkmanx,
Show 1 more comment
0
Score
Avatar
rj713
33.9k
Answered
PermalinkHistory
I would think the memory, hard drive dvd drive and display are probably ok. How the macbook was damaged will be a better guide of whats good and whats junk. If it was for instance submerged it may well be nothing is usable. If you have access to a monitor you may attempt to power it up and see if it boots. The hard drive and dvd drive can be tested externally but the memory will require a compatible computer. Good luck. Ralph
Edited by
0
Score
Avatar
rab777hp
12.6k
Answered
PermalinkHistory
Although I agree the drives will probably be okay, there are a bunch of ways to check the HDD, however I suggest the simplest one- taking it out and putting it in an enclosure, then connecting and testing from your MBP.
rdklincorporated pretty much has you covered there. Listen to him
0
Score
Avatar
Josh
Answered
PermalinkHistory
while pressing the startup key hold down "d" and when the hardware test window appears, test the hardware to see what works.
Add Your Answer
