Score
Asked
water damaged iPod touch
I recently washed out my iPod. It will power on but nothing else. What can I do?
Edited by: David Hodson ( ) , machead3 ( )
2
Score
machead3
21.4k
Answered
Asked & Answered
http://www.ifixit.com/Answers/View/7228/...
If you accept this answer please remember to come back and mark it.
Good Luck
N.
Score
summer
25
Answered
Score
summer
25
Answered
Score
David Gibson
25
Answered
It sounds like it went through the washing machine, that translates into soapy water, which conducts electricity even more ...a bad thing. It also likely did more damage than say ...just falling into the toilet for one second [common!]. The damage has been done by backwards routing of battery voltage and breaking conduction between internal layers/connecto
Solution? Christmas is fast approaching... Apple techs can also detect water damage, so warranty coverage may be out, but if you are a pretty girl or know a pretty girl, she/you may be able to sweet talk a nerdy electronics counter person into a swap. That's my best advice other than sending to Apple for repair.
I have dried many similar devices with 97% isopropyl. At the pharmacy you will find two grades, and obviously 97% has way less water than the 70% and will work best for displacing hidden moisture. The problem with your device was the inability immediately remove the battery soonest upon dunkage [water]. More importantly using alcohol to dry electronics is for advanced Technicians only, please read.
[CRITICAL] The liquid isopropyl is highly flammable and the vapor is explosive. Use with adequate ventilation which is not a nearby electrical fan. You MUST be sure to not have the battery [or any source of spark!] installed when using highly flammable 97% isopropyl on any electronic device. Read other warnings on the isopropyl package and read the Material Safety Data Sheet here
Besides burning without a visible flame (am I on fire?) or exploding (Gramma is that you ..but I thought you were dea...?) concentrated alcohol can remove the oils from your skin, resulting in a minimum, painful hangnails [wear nitrile gloves?]. So your DIY necessity should truly be a Risk Assessment. Is it worth it? Feeling confident? Safety first! Music on your iPod is like 28th, according to Maslow's hierarchy of needs
Edited by: David Gibson ( )
0
Score
nick
15.3k
Answered
Take it apart and put the parts in Isopropyl Alcohol(99%), this will remove ALL corrosion
Put everything in besides the screen assembly and digitizer, these are fine after 9 out of 10 times and may crack during disassembly(dig
I would just refer to established guides that will help with the cleaning as well as the disassembly i.e. http://www.ifixit.com/Device/iPod_Touch_... and http://www.ifixit.com/Wiki/Electronics_W... It is less confusing and that way everybody is on the same page for any follow up questions.
