Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Questions View all
Screen shuts off immediately!
I have the metioned iMac here where i replaced the optical drive. I tested it (with the front bezel off) and everything was great. The suddenly the screen died.
Now, when I switch it on i see the grey startscreen for a second or two and then it gets dark again. I zapped pram and SMU. I tried to boot it from CD. No change. I haven't hooked it up to an external monitor but will do so in a minute and post the results. It appears to start normally (although no picture), it chimes, the fans and HDD operate as usual.
Any idea?
Score 1
1 Comment
Solved - after reassembeling everything it worked again. But still leaves some questions open. All cables where secure. Did anybody else had this experience?
by
Add a comment
1 Answer
Chosen Solution
Often cables and blocks
appear to be connected when the are in fact not.
N.
2 Comments:
Also a twist in the cable could open or close a hidden short.
by
My thought was that the LCD needs some sort of a "ground" connection. When i tested it, the display wasn't screwed down a perhaps only made accidental contact with the EMI shield.
by
Add a comment
Add your answer
remacberlin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,094
