Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 Questions View all
My MacBook has recently popped open now beeps-what do I do?
While working, my macbook made a popping noise, like a gunshot. Now it only beeps like a truck backing up when I start it up. The rest of functionality is completely frozen. What do I do if it is just past warranty?
Score -1
Add a comment
Most Helpful Answer
Jessi Reel, the popping noise needs to be investigated properly. You will have to disassemble your MacBook, use these guides MacBook Pro 15" Unibody Early 2011 and take a good luck at the components. Check for any charred, missing or burned components. Also check your battery and make sure it is in good condition. Once you have done that, let us know what you found.
Score 1
Add a comment
Popping noise sounds like the battery exploded. Open the bottom cover and remove it to see if it bulges. The macbook should still boot without the battery, so you can test it.
Add a comment
Add your answer
Jessi Reel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 82
