Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2399 Questions View all
Compass doesn't work after replacing display assembly
I dropped my iPhone 4 and cracked the screen, so I followed the repair guide to replace the display assembly.
After replacing, all the functions are doing well, but the compass is not working. I open the compass app, in the calibrate screen, the red dot does not roll around, and then entering the compass screen, the compass does not spin around.
Did I touch or miss or broke something while repair the display assembly?
Score -1
Add a comment
1 Answer
It's possible the drop could have damaged the gyroscope..
Does the apps still move around on the home screen when you tilt the phone up and down?
If not then the gyro has been damaged and a motherboard repair is needed..
First of all tho I wouldn't rule out that a restore might fix this issue try that first.
1 Comment:
No, the compass does not work at all.
But I suppose the gyroscope is functioning,I installed Labyrinth to test it and the game is well functioning.
So maybe a restore might help, maybe I'll try it this weekend. Thanks!
by
Add a comment
Add your answer
Foggzhang will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 315
