MacBook Pro Not Charging, battery draining while plugged in.
So recently my Macbook Pro 13inch, 2.8ghz, 2011 decided to go for a swim. During that swim I fried my power connectors and battery. After properly drying and cleaning the boards from the Macbook it was all reassembled to find the dead parts. After using my computer on just the power adapter for a few days while waiting on the new battery (the magsafe port came before the battery) I discovered that not only was the battery not charging, but it was draining rapidly. So some background, while using the computer on the adapter I experienced numerous shut downs all variating in time, with the computer sometimes remaining on for hours at a time, and at other times just seconds. I am no stranger to my macbook, repairing them for business, so I was upset at the fact that I could not solve this problem on my own. I have been using the laptop with the battery that arrived today while it has been plugged into the ac adapter. The dropdown menu of the battery icon states "battery is not charging Power source: Power Adapter" but the battery is still draining going from 65% to 33% in under an hour of plugged in usage. The adapter faces backwards to ensure it is in battery bypass mode, but it is still draining. I don't know what to do I need my laptop and dont have the money to buy another computer with the same abilities as this.
Power Specs
Battery Information:
Model Information:
Serial Number: 9G2500J3LD3MB
Manufacturer: DP
Device Name: bq20z451
Pack Lot Code: 0
PCB Lot Code: 0
Firmware Version: 201
Hardware Revision: 2
Cell Revision: 158
Charge Information:
Charge Remaining (mAh): 2770
Fully Charged: No
Charging: No
Full Charge Capacity (mAh): 5737
Health Information:
Cycle Count: 2
Condition: Normal
Battery Installed: Yes
Amperage (mA): -2402
Voltage (mV): 11200
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 0
Disk Sleep Timer (Minutes): 0
Display Sleep Timer (Minutes): 180
Wake on AC Change: No
Wake on Clamshell Open: Yes
Wake on LAN: Yes
Current Power Source: Yes
Display Sleep Uses Dim: Yes
PrioritizeNetworkReachabilityOverSleep: 0
Standby Delay: 4200
Standby Enabled: 0
Battery Power:
System Sleep Timer (Minutes): 10
Disk Sleep Timer (Minutes): 10
Display Sleep Timer (Minutes): 2
Reduce Brightness: Yes
Standby Delay: 4200
Standby Enabled: 0
Hardware Configuration:
UPS Installed: No
AC Charger Information:
Connected: Yes
Wattage (W): 60
Revision: 0x0000
Family: 0x00ba
Serial Number: 0x002b46f4
Charging: No
Thanks all
Add a comment
