Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Can't remove 2nd screw in the 1st Step
Using the #00 screwdriver, I was able to remove the first screw but am having complete difficulty with the 2nd screw by the charging port. The screw doesn't seem to catch onto the screwdriver. Any tips on how to remove it?
Score -1
Add a comment
1 Answer
The screws on the bottom are not #00. They are pentalobe, which is a proprietary security screw head used by Apple. You should use a pentalobe driver and you will be able to get it out no problem. It is also good to use #000 on the inside of the phone as this will help reduce strips and breaks on the phillips that are inside the phone.
Add a comment
Add your answer
rmehul423 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 93
