Repair information and guides for the fifth generation of iPhone. Model: A1387
2191 Questions View all
The volume buttons won't work one my iPhone 4s
when i click the volume buttons, the screen just says ringer, the sound doesn't work for spotify, youtube, and it's doesn't ding for texts or notifications, but if i set up an alarm, or go into setting and mess with the sounds and alerts bar, the sound works. i don't know what's going on and i need help!
Score -1
Add a comment
Most Helpful Answer
Be sure your phone has been currently updated
Is your phone in silent mode? Check the side of the phone where the vibrate/silent button is located. Also be sure to go over your settings as well to ensure everything is set up correctly
Score 1
Add a comment
I have had this problem before usually means the iPhone is in docking mode and would need a replacement dock connector.
Before replacing this part try cleaning the port with an unused tooth brush and some pure alcohol.
Hope this helps :)
Score 1
Add a comment
I'm having the same problem thinks its got to do with the new iOS on iPhone 4s
Add a comment
I normally isn't a problem with the IOS. Clean out the charging dock with a clean toothbrush, there should be no need to use rubbing alcohol. That is what worked for me.
Good luck!!
Add a comment
Add your answer
jade will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 7,212
