Score
Rob
13
Asked
Power Supply, Overheating components, Voltages Out Of Spec.
The power supply in my Marantz Receiver is way out of spec, I need to figure out why, at the 20v side iam getting 30 volts at the 24 volt side iam getting 28 volts, this is causing a mosfet to cook and it is also causing 4 transistors to cook, ive replaced them, it works but they get scary hot, I replaced 2 ceramic disc caps on the psu along with a resistor, This model is a exact twin of the Carver 895 receiver, Please help. This IS one a regular 120 volt ac line.
Score
Jaybird200
183
Answered
Any chance of finding a schematic?
There would not be a 110v/220v switch that might be in the wrong position? (I had to ask).
I am guessing you are not hearing a 60Hz hum, so it is probably not a filter cap. See if there is a reference zener (looks like a diode). It may be labeled CRx or ZNx, VRx or Vrefx. These are available in many values, but are only stable in certain values (that's Physics for you - only partly stable). If the reference is bad the output would only go a few volts high or low which should produce that symptom.
The 110/220 volt switch in the wrong position would result in a low voltage, not a high voltage
Dave,
It was not specified whether the unit is connected to 110v or 220v. If it were connected to 220v with the switch on 110v......
Wow, you assumed 60 hz, and I assumed 110v... Doh - both right! I think his English convinced me...
Dave,
The high voltage tag should be reserved for >110V. I understand that the voltage in your power supply is high, but that tag means "Above normal mains voltage". Typically 400V+, like you find on most US Navy equipment.
Dave,
You have either a zener diode out of spec, or a resistor out of spec. Without a schematic it is nearly hopeless.
Dave,
http://www.manualsnguides.com/results.ph... was No Help.
Dave,
Is the SR-92 the same as the SR9200? These guys will sell you the Service Manual for the Marantz SR9200 for $20 in PDF format. That includes the Electronics Schematic(s). Just schematics runs $15 http://www.manualsparadise.com/ShowProdu... Make a note of the Service Bulletins, including the Firmware Upgrade! They might also be worth having to keep your antique tuner/amp in top condition. Where are the schematics on ifixit.com???
Dave,
There is no firmware on this, its not the same as the 9200, A Carver 895 is identical, I do have a service manual for it , i nearly replaced everything on the psu circut board and iam still having issues.
Rob,
Rob, if you replaced EVERY diode, and EVERY resistor, with new spec parts, including percentages, then I have no ideas - almost does _not_ count. Find a master electronics tech, and ask a favor or $$$. Unless you want to check for broken through-holes and busted traces, which requires de-populating the board.
Dave,
One more thing! Have you checked the transformer output voltages? A short on the input side in just the right place could drive up the output voltages, which night give what you are seeing. I expect this was the very first thing you checked, since you have the service manual, which should give the Xfomer specs.
Dave,
Show 2 more comments
