Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
Power & Sensor Replacement Problem
I have a Iphone 4 At&t phone that had a broken screen and power button would not work. I replaced the screen and everything worked fine and once my power & sensor cable came in I replace it following the tutorial and video on here.
At first I thought that I had killed the mother board since the phone would not boot up. I connected the mother board on another iphone and it worked fine. So i decided to connected just the charging dock, and screen cables to the motherboard can connect it to my laptop. It turned on so then i decided to connect the front facing camera. That also worked, now I connected the power ribbon to the board and it doesn't turn on, but when i do disconnect it i turns on!.
So what can be causing this? Am i missing something?
Score -1
Add a comment
Chosen Solution
Power ribbon is faulty get another and you should be grand.
Disconnecting is messing with the connecter somehow and turning it on
Score 1
Add a comment
Replace the flex cable of power button and proximity sensor cable too.
Then try will work.
Add a comment
Add your answer
Jose will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 134
