Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Questions View all
What is the piece of glue on top of transistors?
While drying logic board in rice, I mistok a piece of glue on the logic board near the ethernet connector for a piece of rice, and removed it.
On pictures I now see it is intended to be there. It covered two small transistors(?) or units with blank surfaces.
The glue is semi-transparent, and was applied as a thick line above them.
Do anyone know what the purpose of this is, and the consequence of removing it? No apparent damage to the components.
Score -1
1 Comment
Powered up, and so far so good. Advice at electronics.stackexchange.com suggests its no big deal.
by
Add a comment
1 Answer
Chosen Solution
Sometimes the humidity in the air is enough to alter the transistors function so many electronic device suppliers cover them (not just Apple). Often they use a light hot glue or silicon sealer that is fast setting (UV).
Score 2
Add a comment
Add your answer
Christian will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 91
