Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Cannot restore with iTunes after replacing battery
This is what happened.
I replaced my iPhone 5S's battery, but I lost the screws for the metal battery connector bracket(is this part important at all?). I thought it was unimportant so i just put the entire iPhone together anyway.
Turned the phone on, everything worked as per normal. For some reason I wanted to restore the phone. Plugged into my PC and clicked restore on iTunes. Error 1 came up, then my phone got stuck in recovery mode. Tried repeatedly, kept failing.
What should I do? Below are the methods I've tried.
Put into DFU: Didn't work, still Error 1.
Change USB ports: Didn't work as well.
Use TinyUmbrella: "Fix Recovery" didn't work.
WHAT SHOULD I DO? ):
Score -1
Add a comment
1 Answer
Error 1 as far a I no cannot be fixed it's a hardware problem..
I would chance going to apple an getting a new1 through warrenty..
And don't say you done anything to it..
Add a comment
Add your answer
Derrick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 273
