Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
White screen when put to sleep
After replacing the vibrate motor in my iPhone it has a white screen when woken up from sleep, the only way around it is to reboot. ( Home button + Power button ) I've tried everything from restoring it,
( both in DFU and normal )
and all kinds of button combinations.
Removing the mainboard for an hour.
The phone works normal, if I set the auto lock to never. I've read that it could mean a bad LCD, but why would it show a white screen after locked but work normally when not locked ? Could it be because I didn't turn the device off when unplugging the display ? ( The screen was off though when I did it.)
All the cables are connected properly.
Score -1
2 Comments
Bump........
by
Replaced LCD and iphone is working again.
by
Add a comment
Chosen Solution
This problem is due to faulty LCD Display. Replace the LCD Display. Make sure iPhone is OFF when you replace it, or you will damage the LCD Display, or the logic board.
1 Comment:
Thank you, I just ordered one, I'll post back after I've installed it.
by
Add a comment
hi there have a customer with the same problem and is leaving phone off later im going to try a lcd from a working 3gs see if that cures it il update my progress
2 Comments:
Great, Thanks.
by
Any updates ?
by
Add a comment
Just an update changed the lcd and phone is working 100%
Add a comment
Add your answer
CreativeMagic will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 156
