Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
iPhone5 home button not reponding..
Hi Admin,
Recently, i replaced my iphone5 internal speaker. But after i assembled my home button is not functioning already so i decide to replace the home button (switch) and the lighting charger assembly but still does not work. May i know whoelse encounter this problem? How u fix the issue?
Score 1
1 Comment
Hi Con,
Thanks for you prompt response and technical advice.
Yes, i already shorted this two prongs using screws but no response. Is it possible that i damage the mainboard when i install the internal speaker?
Isolation made:
1. I already isolate the speaker itself (damage one and new one) but the home button is not responding anymore.
2. I also replace the "lighting charger, headset jack" assembly but its the same.
3. I measure the two prongs voltage reading with respect to gnd. One has 1.72V and the other one has 0.0V.
4. The one the measure 1.72V has an open resistance while the other with 0.0V got 10kohms.
Let me know of your taught. Thanks so much.
by
Add a comment
1 Answer
Most Helpful Answer
Make sure phone is turned on Open up the iPhone again just a tad so you can see the little gold prongs on the dock connector inside the phone. Now with a screw driver touch the two prongs at the Same time this should activate the screen as it's mimicking the home button when active.. If it does then good it just means you need to push the prongs up a tad so they come in contact with the home button flex.. If not then could be a faulty part
Score 1
3 Comments:
Hi Con, Thanks for you prompt response and technical advice. Yes, i already shorted this two prongs using screws but no response. Is it possible that i damage the mainboard when i install the internal speaker? Isolation made: 1. I already isolate the speaker itself (damage one and new one) but the home button is not responding anymore. 2. I also replace the "lighting charger, headset jack" assembly but its the same. 3. I measure the two prongs voltage reading with respect to gnd. One has 1.72V and the other one has 0.0V. 4. The one the measure 1.72V has an open resistance while the other with 0.0V got 10kohms. Let me know of your taught. Thanks so much.
charles morgan, 2 hours ago • Delete
by
Any update please.. Thanks!
by
Hi Charles I wouldn't be technogly mind in the componant end of the iPhone so I wouldn't really have a clue what voltage the phone should be.. Someone on here should no tho
by
Add a comment
Add your answer
charles morgan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 240
