Released in North America in November 2006, the Wii was Nintendo's first home console to directly support Internet connectivity, supporting both online games and digital distribution of games and media applications through the Wii Shop Channel.
289 Questions View all
My wii don't start up
Hi,
My wii gives me an error, i don't remenber how, and then i turn off my wii and it never sart up again. when i power on my wii stays in black screen.
Is it an way for start up by an sd card with some specific software or else do a reset that comes back the factory memory?
Thanks,
Vitor
Score 1
Add a comment
Most Helpful Answer
Either your WiFi module or bluetooth module is broken, or the contents of your NAND flash inside the unit are corrupted. You can try swapping out the two modules with those from a working device, but if that doesn't work, you will have to send it to Nintendo for repair (or replace the main board). There is no way for you to repair the flash memory yourself.
Nintendo Wii Motherboard Image
Product
$44.99
Score 1
Add a comment
This may or may not be the same problem/solution, as your problem doesn't have enough detail.
Wii console input output doesnot work
Add a comment
Occassionally our Wii console won't power up, no lites or anything. I found that unplugging the power supply for abtout a minute has solved it so far.
Anyone have any ideas about a more permanent fix?
Add a comment
Add your answer
Vitor Leite will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 2,905
