Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Questions View all
Question Closed
4 screens down, no screen prompts just a tiny flicker
I have an iPhone 4S ive been putting together the phone worked fine before i did a logic board swap and replaced the power flex, now when i put on the new screen, it barely flickers and the corners go dark on the screen, i thought maybe the frame but when i switched it out i got the same problem, did without the frame and i had the same outcome, the board doesnt have any damage. Anybody have any idea what it might be?
1 Comment:
Did that, still a no go
by
Add a comment
Try the old screen see if it still works ok sounds like a damaged screen
4 Comments:
If the old screen was working before and now it's not then look at the connector pins on the motherboard to make there not bent
by
by
tell me this what ios are you running on the phone
by
Jordon what iOS is the iPhone running?
by
Add a comment
If you switched the logic board, then you have a new phone. If the old screen and new screen aren't working, then your new logic board has a problem, or both screens are damaged.
It is fairly common for "new" LCD assemblies to have this kind of problem, and it is also common to tear an LCD cable when taking out an old screen. It may be worth it to try a third screen before deciding that your new logic board has an image problem.
1 Comment:
I'm leaning towards logic board damage, I've gone through 8 screens, 2 different frames...... and my last nerve
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 92
