Question Closed
Why won't my A1261 boot after I replaced the hard drive?
My A1261 MacBook Pro 17" worked great until I decided to upgrade the hard drive. I changed the hard drive only. After I put it back together, I started it and all I got was noise from the super drive no chime no display. The sleep light in front goes bright and dim. Then there is a pop noise and it turns off.
I have tried all the resets. Still same problem. I put the old hard drive back in. Same problem. The ram wasn't touched. But I tested each stick separately. Same problem. I sure wish that I had left the hard drive alone.
Any thoughts?
Thank You,
Doug Ditmore
Add a comment
1 Answer
You did match (within one version) the SATA speed of the new drive to that of the old drive/bus of your machine? Serial ATA (1.5 Gb/s) fastest drive interface you can put in is a SATA ii drive 3Gb/s...
Check that the drive is fully seated in the slot. Try an SMC reset. Of course you had no power connected when you did the swap.
If this answer is acceptable please remember to return and mark it.
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 77
