Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Question Closed
What to replace in non-vibrating iPhone
My iphone 4 stopped vibrating two weeks after I got my phone. I've had then phone now for a year and a half and want to fix it so that my phone will vibrate again. What replacement parts do I need to order and learn how to replace?
Add a comment
Most Helpful Answer
Hi there it can be 1 or two things
It's either the motor has burnt out or it's the actual headphone, silent or volume flex.
Before you order any parts you could just take out the motor and bend the little prongs slightly and see does this sort it
iPhone 4 Vibrator Replacement
iPhone 4 Vibrate Ring Switch Replacement
iPhone 4 Vibrator Image
Guide
Difficulty:
Moderate
20 - 40 minutes
iPhone 4 Vibrate Ring Switch Image
Guide
Difficulty:
Difficult
Score 1
Add a comment
Also, the 4 GSM and the iPhone 4 verizon use different vibrators. the Verizon/CDMA version uses a button shaped vibrator, like in the 4s.
iPhone 4 Verizon Vibrator Replacement
make sure you buy the correct part, if you need to take that path.
Guide
Difficulty:
Moderate
20 - 40 minutes
iPhone 4 Verizon Vibrator Image
Guide
Difficulty:
Difficult
1 - 2 hours
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 60
