2, 2.26, 2.53, or 2.66 GHz Core 2 Duo processor
106 Questions View all
Question Closed
CPU thermal sensor + Speaker cable connectors broken
Hello,
Can anyone advise whether it's possible to source connectors that a CPU thermal sensor and Speaker cable used to attach to as a Mac Mini 2.26 GHz that I've bought has had both of these torn off the logic-board unfortunately. The connector that was soldered to the logic-board for the CPU thermal sensor wasn't provided but the one connected to the flying lead coming from the Speaker is still attached (to the cable not the logic-board).
I'm 'okay' with soldering but haven't soldered anything quite as fine / delicate as this but would give this a try should this be a recommended fix.
At a guess the connectors are not sourceable by themselves failing that would be desperately expensive.
Thank you for any help with a possible fix.
Add a comment
1 Answer
Chosen Solution
Grabbing a damaged logic board or machine off e-bay might be a source. Of course you want to specify that those connectors can't be damaged as they are your main interest in the "for repair only" logic board.
If this answer is acceptable please remember to return and mark it.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 205
