Repair manuals and information for the Microsoft Surface line of tablets.
128 Questions View all
Seperating the touch glass from the LCD screen?
I read the tear down for the Surface RT and have a good idea of what to expect.
But the one thing that was left out was how to separate the Touch Glass from the LCD screen?
I just dropped my RT and have cracked the glass and the touch digitizer isn't working properly (LCD display is fine). I have found a replacement glass digitizer on eBay for a reasonable price, but at the end of the tear down it says:
"LCD and glass are fused together and strongly adhered to the case, increasing cost of replacement."
and
"You'll have to use a heat gun and lots of patience to gain access to the glass and LCD."
But I can't locate a guide on how to separate the two for either replacement. Help?
Add a comment
Chosen Solution
This is another old one but I feel it deserves some clarity. There are many options out there for original Surface RT screen replacement. You can get them in 3 different ways
1: screen/digitizer/glass/mid-frame bezel as an assembly. This is the way Microsoft sold them, and is by far the easiest option. You can get them right here on iFIXIT.
2:Screen/digitizer/glass assembly. A more affordable third party option, available on e-bay or amazon among others. To replace this you will follow the same procedure as you would for a Surface 2 or 1st gen pro. Because ti was not intended to be replaced this way you should be very cautious of the ribbon cables connecting the digitizer. They are very short and easily damaged.
3:Digitizer/glass only. No screen, no frame. THIS IS A TRAP. Not a joke, I mean it. They are on ebay and Amazon also, selling for a low $13 or so. The problem is that to seperate the LCD screen from the digitizer you should really use a heated vacuum machine or you will have to break the old glass and remove it piece by piece to avoid prying on the screen. Then you have to clean all the glue off of the old screen perfectly, which requires caustic chemical solvents like N-Hexane. Then apply the correct clear adhesive called LOCA, which requires UV lights to cure. Then finally reglue the screen to the new digitizer, which you should use a specially designed mold to line up the screen perfectly and a vacuum press or laminate machine so you don't end up with very visible bubbles and/or debris particles in between the two. TL;DR, a DIYer is NOT equipped to do this properly.
Now I have seen some unique fixes done to these. I have seen people by the cheap option and then simply not glue the screen to the glass. It's hazy that way and you get glare but it looks better than gluing it improperly. They just tape it in with some 2mm tape. (NOT recommending this just saying I have seen it). Since the original RT is not supported by Microsoft anymore, your only options are to do it yourself or take it to a private repair shop/person. If you do it yourself, educate yourself. Make sure you know what you are getting into. If the replacement part you are ordering is different, or mising something that the official replacement had, you should consider the reason the original part was sold the way it was. If the price difference is extreme, take a close look as to why.
Score 2
1 Comment:
I would also like to add for Microsoft surface Pro 3 screen replacement or all glass in general for surfaces is that most likely any crack on the glass will cause the touch screen to stop working properly as the touch screen layer is fused with the glass.
So if that happens you will need to get the whole screen replaced.
For any dented frame issues only replace screen if you can actually bend them back in place for the screen to fit decently. If not then do not get the screen replaced.
by
Add a comment
You need heatgun and some cards to separate. You can watch this guy.
http://youtube.com/watch?v=1dhY51GqD2M
Good luck ...
Score 1
1 Comment:
Really? I can't believe you would recommend a video on How to wreck your surface. Really bad video.
by
Add a comment
Hello. If I just buy a new glass and lcd assembly then that would not be too hard to replace correct? At least doesn't look like it from the tear down?
Add a comment
You don't have the proper equipment to readhear a new glass to the LCD. You probably also just ordered a piece of glass which doesn't have the digitizer attached to it.
You're going to have to order the entire display assembly to repair your device.
Add a comment
Add your answer
Dirk will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 50
All Time: 6,708
