2
Score
Peter Norby
25
Asked
Mac Mini light comes on, but no chime.
I purchased a 1.66 Core Duo mini early last year, ran sata out the side, and upgraded to a T7200 processor. Over the past month, I got a couple of lockups under load (importing CDs), and once a GSOD.
Last week, I woke up to find my mini completely dead. The power light was still on, the hard drive was still spinning, but nothing going on. I powered it off, and back on, and it still sat silent. The light came on, but no chime, and no booting.
What I've tried so far:
- resetting the PRAM => fan runs @ max until I turn it off, front light does not come on.
- resetting the SMC => back to the normal state where the front light comes on, but nothing else.
- replacing the original 1.66 Core Duo CPU to see if I'd smoked the T7200.
- pulling one of the 1G chips out, and then the other.
At this point, is there much chance that it could be anything but a failed logic board? (The thing was quite dusty around the intake vents ...). I suppose it could be the power supply, but it seems sort of unlikely.
Nobody seems to sell logic boards, so I guess it's time to pick up the cheapest old mini I can find ($350 is what I've seen), or fork over ~$750 for a brand new one.
5
Score
markus weiher
21.4k
Answered
hi peter,
since you already took it apart, i think you don't need the guide
you already tried a few things, but i tell you what i would do in that case -s o if there is anything mentioned what you already did - ignore it ;-)
does the led flash a few times when you power it on ?
try to start from the setup dvd that came with the mini(press c when you switch on the mini)- (btw - what os do you use ?)
if it starts from the disk, try the disk utility to check/repair the permissions/har
if that wont work - go the hard way
remove almost everything whats inside - ram, wifi card, hdd & dvd
try to power it on - normally the led should flash 2 times in that case - the mini would recognize that no ram is installed
normally there are beep codes - but i had a mini that didn't make any sound
1 beep = no RAM installed
2 beeps = incompatible RAM types
3 beeps = no good banks
4 beeps = no good boot images in the boot ROM (and/or bad sys config block)
5 beeps = processor is not usable
the flashing led is beep code plus 1 (no ram equals 2 flashes)
if that works, shut it down and try putting the ram in and start it again - if that also works, you should see a grey screen with a folder/question mark - shut the mini down
now connect the hdd and try booting the mini again - if it works - you should be able to start the system
now you can try the same thing with the optical drive and the wifi card - if the system stops on any point - you have found the faulty part.
you can also change the order or better - if the hdd won't work, try to go ahead with the optical drive and so on.
sometimes is the disconnecting/c
but keep in mind - the psu can be faulty
i hope that i didn't forgot anything ;-)
The white LED comes on solid, no blinking. No chime - will not boot from DVD or HDD (was previously running with 10.5.8). I just pulled all of the RAM to see if I could coax any blinking out of it, and nothing. Next step, I suppose, is to see if I can cadge a power supply off of somebody, and/or see about checking the voltage coming out of it. Thanks for the comprehensive list of suggested steps! -/\/
2
Score
mayer
121.8k
Answered
0
Score
James
Answered
0
Score
Peter Norby
25
Answered
0
Score
midwave
Answered
I had a late 2007 Mac mini and took it in to have it looked at by an Apple staffer at a storefront (same situation as described in this post). He didn't do nearly as much as I had done, and seemed tethered to what he could do on the keyboard, which did nothing. He tried a separate power brick and the behavior was the same as described in this post. It was hot in the room the day it failed (screen went off in the middle of usage). His guess, which was no better than mine, was that the logic board failed. He offered to do more, but I asked him how much the repair would be and he agreed that any way I looked at it, probably $100's to fix. I parted and three cheery, un-caring sales clerks wished me a good day as I left, looking very sober and disappointed. I'm currently using a $6 SATA enclosure and pulling my data off and onto an NTFS storage drive using some HFS+ capable software from a SourceForge project.
0
Score
Andy M
Answered
I have a similar problem with an A1176. The screen froze when loading a new browser page. alt/cmd/esc did nothing but I did notice that the fan although not running fast did blow fairly hot air.
I lifted the lid and tried to start it again (cmdS mode) and the thing had a kernel panic right away with the CPU getting very hot. I tried installing the original 1G RAM but no difference. Shortly after switching on, the CPU got very hot and there was no longer any response from the k/b. My suspicion was that the CPU had fried so I replaced it with an Intel P7350 which I believe to be the right one.
Now when power is applied and the power switch pressed, the k/b has no effect (no caps lock light) and there is nothing on the screen at all. The fan runs but it will not accept a disk in the optical drive so I'm beginning to think that there is a power fault on the main board. A long shot I know but does anyone have experience with the main board?
Many thanks.
0
Score
pfbloom
Answered
Same problem: my A1176 was running fine on the original 1.8 Core Duo, but I got the parts and went for the upgrade:
- Upgrade CPU to Core 2 Duo 2.0 GHz
- Upgrade RAM to 2GB
- Upgrade HD to 500GB WD Scorpio
Followed directions here, which were great and thorough. Completed the processor upgrade too, despite trepidation. Reassembled carefully (actually twice for troubleshooting
Now nothing: or almost nothing... Mouse lights up at power on, fan starts, and HD spins up, but no LEDs and no startup image. I'm thinking I either got a bad CPU, or damaged the MB in the upgrade.
Did the PMU reset, disassembled and reseated all components and cables. No luck. Sometimes you win, other times..........
One thing I didn't mention above was that if I left the fan cable unplugged, the fan would spin up ~5 seconds after powering it on. If the cable were plugged in, it would spin up, but at a very low RPM (hard to hear outside of a quiet environment). -/\/
Peter Norby,
