Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Question Closed
iPhone won't power up and battery won't charge after replacing
I've read through all of the battery-related questions I could find, and I think that I may have just received a defective battery, but I thought I would throw this one out anyway since I didn't see anything that exactly matches my situation.
I bought the iFixit replacement battery kit, and the replacement went according to plan. I tried powering on the iPhone to test it, but I got the empty battery gauge with the thin red line and the icons underneath it showing a plug pointing to a lightning bolt.
I then plugged it into the wall charger, but I never hear the happy "I'm charging" chirp. Both charger and cable are Apple and work fine with my other iOS devices. The icon below the battery gauge changes to a lightning bolt only, so I know it's detecting the charging cable.
Since I get the screen with the empty battery gauge even if unplugged, I'm assuming that the power contacts on the battery are connecting properly.
I've left it on the charger for several hours, and it never moves off of the thin red line, and I don't feel the back of the iPhone get warm.
I went ahead and disassembled the phone again. Reassembled it, checking all the cables and connectors, making sure the contacts for the battery were clean, and made sure all the cables were seated firmly. Everything looks fine, but I still just get the empty battery gauge. I can't replace the old battery, because it's all puffed up, and I don't really want to risk the possibility of it catching fire or anything.
For what it's worth, I put a multimeter to the battery contacts. If Pin 1 is closest to the dock connector, here is what I got when I connected the following pin pairs:
1-2: 0 ohms
1-3: 2.4V
1-4: 4.09V
These figures are consistent with the values reported in an answer that I read here. I'll leave conclusions to those with greater knowledge of the workings of the battery packs.
Is it possible that it's a simple case of having received a defective replacement battery pack?
1 Comment
iFixit immediately sent me another replacement battery with the same part number 616-0434, and the iPhone powered up just fine. Turns out it was a simple case of the first replacement battery being DOA.
by
Add a comment
Chosen Solution
First replacement battery was DOA. Second replacement battery works just fine. Just bad luck with the first one.
Score 1
Add a comment
iPhone 3gs required battery part number 616-0435. Battery 616-0366 are compatible only with older iPhone 3G. If you put wrong battery you vill have problem with charging and restore IOS.
2 Comments:
They're sending me a replacement battery, but I'll check that when I open it up again.
by
Stock battery was 616-0432, and replacement is 616-0434, which is also an appropriate p/n for the 3GS.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 723
