0
Score
Avatar
gareth jones
Asked
not charging after water immersion.
History
wife's iPhone died after getting wet,dried out,would switch on but not charge,changed the battery using great fixit guide.(connector 3 is a hard one,better pic maybe?).will switch on ok but still won't charge,any ideas please ??
thank you both for your time and taking the trouble to help a novice techhead.will try the cleaning first and if no good the dock connector
gareth jones,
you're welcome ;-)
markus weiher,
alas new dock connector,battery and a good clean up have failed to work.phone functions ok except for taking a charge.thanks for the sound advice though.
gareth jones,
Post Answer
2
Score
Avatar
Jakob
25
Answered
PermalinkHistory
had the same problem with my iPhone 3G.
replaced battery,dock connector...
checked charge/usb chip
(Linear Technology LTC4088-2 Battery charger/USB controller)
http://cds.linear.com/docs/Datasheet/408...
check vbus=5v
in my case I had to change the LTC4088 and another chip this position (backside/logic board)
http://forum.gsmhosting.com/vbb/f456/iPh...
if your ltc4088-2 chip is ok check the "position" shown the link above.
its not easy!!!but now its ok!
read this: (to see pictures you have to register (free))
http://forum.gsmhosting.com/vbb/f631/iPh...
http://forum.gsmhosting.com/vbb/f456/3g-...
http://www.yobbgsm.com/2010/04/iPhone-3g...
(usb-solution)
nice - but to be honest - most of those repairs/hacks/unlocks are nothing for the "standard user" - mostly half legal vendors in the background. i have 2 accounts there - my first one is from my old cell phone repair days in 2001 ;-)
markus weiher,
0
Score
Avatar
markus weiher
22.9k
Answered
PermalinkHistory
fluid damages are always problematic - there are sometimes tiniy shorted parts on the logicboard and the dock connector.
those parts have to be cleaned carefully with a soft paintbrush and rubbing alcohol - let it dry (really dry) and if everything is clean - reassemble it and try it again
0
Score
Avatar
Jeremy Scalpello
229
Answered
PermalinkHistory
You may have to replace.....either the battery or the dock connector.
0
Score
Avatar
gareth jones
Answered
PermalinkHistory
thanks but i've reached the limit of my tech ability.the good lady will have to look after her next phone !
0
Score
Avatar
carlo
Answered
PermalinkHistory
hello my apple iPhone 3G dropped in water dried perfect but I have a problem everything worked, the touch screen does not work I tried to change it again but do not want to know. how can I fix this? thank you very much.
please start a new question for that
markus weiher,
Add Your Answer
