0
Score
Avatar
christan
Asked
Why wont my iPod touch 3rd generation turn on?
History
I tried to jailbreak it and it wont turn on
Post Answer
0
Score
Avatar
Jeremy Wenrich
95
Answered
PermalinkHistory
Worst Case: It is bricked and may need to be replaced.
Best Case: It is just a little messed up and needs a little push. Connect it to power via a wall outlet instead of your computer. Try holding the top (wake/sleep) button and the home button for about 10-20 seconds.
Others may have better suggestions.
0
Score
Avatar
nick
15.3k
Answered
PermalinkHistory
Either its bricked OR you need to restore it
to restore hold the sleep/wake button and home button til you see all sorts of code
Dont worry its fine!
0
Score
Avatar
Ben
Answered
PermalinkHistory
(Read entire post before trying anything, Not responsible for any damage to your iPod as a result of my post.) Try putting it into DFU Mode and restoring it. If you don't know how to do that Google would be your friend. Also it might already be in DFU mode in that case plug it into your computer with itunes and restore it. Then try jailbreaking again. I'd recomend Spirit or blackra1n or redsn0w. They do a good joob. Also you may have to find a way to downgrade it or Shift click Restore on itunes and pick an older firmware that you previously downloaded
( http://www.felixbruns.de/iPod/firmware/ )and is capable with jailbreaking (3.12 | 3.13)as ios4 isn't compatible. Hope this helps.
P.s. As others have said, jailbreaking voids your warranty and you could be bricked. (Apple disabling your device for tinkering with it. As a result of an unsuccessful jailbreak. Also try using spirit before you restore. ( http://spiritjb.com/ ).
Add Your Answer
