Permanent gray line on screen
There is a permanent gray line stuck across my screen when the unit is on. It is not sensitive to the accelerometer orientation. Is this something that can be repaired?
a defective line across the entire LCD display is almost always a sign of a problem with one of the LCD "driver" ICs- since it's a whole line it's unlikely to be the liquid crystal portion of the display itself dying or a problem with the main logic board or graphics controller or a loose connection between the display and logic board.
These LCD driver ICs drive the row and column voltages necessary for the LCD to operate. So a failure in one of the row or column outputs of a driver would show up as a dead line on the display. Sometimes the failure can simply be a mechanical break in one of the many output lines from the driver to the LCD.
the problem is if it is indeed an LCD driver, it may be difficult or impossible for you to repair without replacing the whole LCD display module - this is because the LCD driver ICs are usually very wide (e.g. 120 outputs) bare silicon chips integrated directly on the edges of the glass substrate or bonded to a thin flex substrate along the edge of the panel - practically impossible to manually replace/resolder.
to understand better, see this example diagram of an LCD module, consisting of the LCD display itself plus source and gate drivers (row and column drivers) - refer to figure 2 on bottom of this page:
http://www.necel.com/magazine/en/vol_000...
bottom line: if you have a defective line on the display, the problem is almost certainly in the LCD module itself (specifically one of the driver ICs or it's physical connection). the display module will likely need to be replaced.
it looks like the screen is dying, most likely, there will be more to come, your best option would be to replace the screen when the problem progresses serverely.
This could be a number of things. The logic board could have an issue causing anomaly in the screen. The LCD wouldn't be the problem here because when it starts to age pixels die not lines in the screen.
You could take the device apart and clean it. Try making sure all the connections are not loose.
Here is the guide to disassembling it:
iPod Touch 1st Generation Display Replacement
If your not up to that take it to apple and see if they can help.
Regards,
-Varsity
Your probably have to replace the display screen. For iPods, I would suggest taking it to a shop if you never have done any portable Apple device repair. iPods are the hardest to repair out of the three (iPod, iPhone, iPad).
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 19,399
