0
Score
Avatar
jimryan
Asked
Which Philips screws on left edge of keyboard area?
History
In step 28 of the ibook g4 Logic Board Replacement guide, the accompanying image shows which 3 screws need to be removed.
The problem is, those top & bottom left screws are different sizes than the bottom right one. What size screwdriver do I need for them?
Edited by
Post Answer
Score
Avatar
rdklinc
15.3k
Answered
PermalinkHistory
Unless they have been replaced with something different, those screws should just be basic phillips screws...any smallish phillips-head screwdriver should do it. I don't know the technical size of the screws, and it really shouldn't matter so much. If they are problematic, I sometimes use a slightly larger phillips, which can give you a better grip.
If you've gotten to step 28, you should already have a screwdriver capable of dealing with those screws, so I get the idea from your question that there's something more to it than that...are they torx screws, or possibly are they stripped?
Thanks. They're neither torx nor stripped; they are standard philips head, but I think they're size 00 as none of my screwdrivers (0,1,0-2) quite fit them. When you get down to the tiny sizes, it seems that exactitude of fit matters more and more.
jimryan,
0
Score
Avatar
lemerise
16.2k
Answered
PermalinkHistory
Small Phillips-head screwdriver.
Add Your Answer
