The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
319 Questions View all
Kenmore Elite h3 dryer won't start
When I make a dryer selection and punch start (or hold start for 2-3 seconds) it will not start. It beeps 3 times, and the time light begins to flash - but it doesn't start the dryer cycle. appreciate any suggestions!
Add a comment
1 Answer
Chosen Solution
most likely you have either a bad door switch or an open thermal fuse. the thermal fuse is located behind the toe kick panel. remove the toe kick by removing 3 screws (t20) at the bottom of toe kick. then open the door and remove the lint filter. behind the toe kick is a fan duct that needs to be removed should be 3 1/4"screws. behind the fan duct is a white plastic fuse that has 2 blue wires connected to it. remove one wire and test for continuity. if the fuse is open replace it. then reassemble in reverse order
Add a comment
Add your answer
Fidele will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 7,596
