Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Stuck problems after replacing battery
I replace my battery and after that my iphone gone slow and dumb. it goes fine until the unlocking of the simm. when i put my pw (it is the correct one) it rights "unlocing please wait" but after that it stays there till i hard reset it. after that it comes ulocked. but if i try to do annything else it stuck again. for example if i try to make a phonecall it will stay there truck in the dialing screen with no action. and there is nothing i can do to cancel the call if i try to , it will stay forever to the cancellation screen. i double and triple checked all connectors what should i do??
Score -1
Add a comment
1 Answer
Most Helpful Answer
Please check date and time settings first. Make sure date and time is correct. After battery replacement date and time goes back to 1960s. And iphone gets confused.
If date and time correct try 2nd solution.
Goto setting
Phone and sim settings. Disable sim pin. That fixes your problem.
Good luck...
Score 1
Add a comment
Add your answer
nikos will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 86
