Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
What would cause Error 29 in iTunes on iPhone 4
I had a shop recently replace my screen on my iPhone 4. After a few days my phone would keep rebooting after 2 minutes every single time. I closed all the apps and turned everything off, including cellular, 3G, roaming and it still keeps rebooting... So i decided to do a restore via iTunes. Now Every time i do a restore and update I keep getting Error 29 in iTunes. I read that error 29 usually means a bad or incompatible battery. I tried batteries from two different iPhone 4. Both were original batteries. I also tried different computers, different cables and I during the update process it gets 3/4ths done and I'm getting error 29 on iTunes. The phone is back on recovery mode..... I can't get it out of recovery mode and I can't get it to update.....
Could the screen replacement cause this error 29. ? Is there any other way to get out of recovery mode or update my iPhone ?
Score 1
Add a comment
change ur battery & then do update process 10000% tested
Add a comment
I've been having the exact same problem. I got my screen replaced and since then the battery is having the exact same issues that you described above. How do you change the battery?
1 Comment:
iPhone 4 Verizon Battery Replacement
This is for the verizon if it's not the verizon or sprint go to the guide for regular iphone 4
by
Add a comment
Add your answer
Mike will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,842
