The PlayStation 3 Slim is the second version of the PS3 video game console with the original model number CECH-2000. Produced by Sony Computer Entertainment it fixed many issues of the original (fat) Playstation 3. It was released on September 1, 2009.
466 Questions View all
Question Closed
Stripped screws EMI shield PS3, can't get them out. Help please!
'''Hello,
The bottom two screws on the motherboard assembly wont loosen at all as they both have been stripped.
I was using the correct screwdriver but they were so !@#$ tight and I didnt have enough power to get them out so they stripped when I tried.
Picture to show what screws I mean:'''
Does anyone have any idea on how to get the stripped screws out ? I don't want to break the motherboard or anything else.
Add a comment
First of all, why do you want to assemble your motherboard?
Hereby a solution with limited damage.
The only thing left to do is to drill out the screws preferably with a small pillar drill, and use a brandnew drill the same diameter as the screw. With a pillar drill you won't slip beside the head of the screw. It is important that you do this gentle.
The only negative thing about this is you can't use the screws and holes anymore but some times you won't need them. Good luck.
Add a comment
If you have a very small angle grinder, such as dremel, you can use it to cut a groove suiteble for a flathead screwdriver. You would have to protect the rest of the mobo from sparks and have a very steady hand. Slip once and it's over.
Add a comment
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 1,019
