Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Question Closed
Weak wifi signal after home button change, tried everything!
I recently changed the home button on my iphone 4. after reassembling it I noticed my wifi signal was extremely poor, so i searched the forums and saw that it might be the screw in the antenna so i tightened it, but it didn't work.. I checked to see if the tiny metal piece that connects the frame to the motherboard was there, and it was. So thinking it might be the antenna i ordered a completely new one and put it in with the new tiny metal piece as well, but it still didn't work!
I don't know if there is anything more i can try.
I even tried connecting the golden circle on the motherboard directly to the other golden thing slightly left from it which connects to the frame, didn't work either. so if there is anything more i can try, please tell me.
Add a comment
1 Answer
is it ATT or Verizon? if it is ATT version sometimes the metal braket on the heat shield can be the issue. If it is still there try putting a small piece of Aluminum foil over it. then put the long screw back in. This worked for me.
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 176
