Repair and disassembly guides and support for dish washing appliances.
702 Questions View all
Question Closed
Get rid of dish soap in dishwasher
My teenager put liquid dish soap instead of dish washer detergent, now everytme I run a cycle the dishwasher floods my kitchen. How do ifix this??
Add a comment
1 Answer
Chosen Solution
Does your dishwasher have a reserve dispenser or just the cup & covered cup setup?
If you have the latter you'll need to wipe down the inside walls with hot water and a rag to remove as much of the residual soap. Take the racks outside and spray them down with a hose. Once you get the insides clean you should not have to much left in the pump & piping. Start it up and once the pan is full let it run a bit. Then with a wet-vac suck out the water. You'll likely need to do this a few times as you don't want it to froth up the suds by running it too long.
If on the other hand you have one with a reserve dispenser you'll need to open it up to get to the bottle and give it a good cleaning. Follow the same steps once you have no new soap getting into the washer.
I guess your teen has a weekend project ;-}
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 178
