The late 2005 Power Mac G5 was introduced in October, and discontinued in August the next year. There were three configuration options, one dual core processor at 2.0 GHz, one dual core at 2.3 GHz with model number A1177, and one dual core dual processor (quad core) at 2.5 GHz.
26 Questions View all
Question Closed
How to determine if power supply or power switch has failed?
I have a late model dual core Power Mac G5 model number A1117 that will not boot up or power up.
It has been sitting idle last operated New Year's of 2011 without any issue.
When I tried to power it up last week from my wife who would like to use it now, initially the white LED above the power switch came on but nothing happened. I tried to hit the power switch again and the second time nothing happened not even the LED above the power switch. I tried unplugging replugging etc. but still nothing.
After reading through the forums I have since changed the backup battery, reset the SMU switch [my version does not have a PMU switch] and all of the steps associated with the answers given for other questions. Still nothing is working and I need to determine if the power Switch is faulty or if there is an issue with the actual power supply.
Can anybody help me isolate the problem?
Thanks,
-David
Add a comment
1 Answer
Hi David! For isolating the problem, find the plug from the on/off switch on the mainboard, unplug it, clean the contacts & hotwire ur G5 with e.g. with a PH 00 philips screwdriver. If you don't get a reaction u can be sure ur power supply is zilched. In this case see the G5 repair section on this site --> Power supply change. The pictures shown here, will give u an impression of what happens to the unit underneath a leaking cooling system.
Good luck
Alex the Kraut
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 342
