2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Questions View all
I hit and broke my USB port, can it be replaced?
In past months I accidentally let my Macbook Pro fell down, and it landed on one of its sides resulting on a broken not functioning USB port, is there any way to replace, I think the internal connection is not compromise. Help please!
Score 1
Add a comment
1 Answer
Chosen Solution
It really depends on what USB port. The USB port on the right is attached to your Logic Board and as Mayer said, it is not a DIY fix to replace just that USB Port. Replacing the Logic Board itself also requires a good bit of technical know how and confidence. You will need to disconnect and remove your Optical drive, both fans, 3 heat sensors, and a few other connections from the Logic Board. You will also have about 9 T6 screws to remove before you can lift it out. You will need to ensure an anti static working surface.
Now, if you're talking about repairing just the USB port... that is going to require soldering skills. Or you can now just replace the Logic Board.
As for the USB Port on the left, that is connected to the DC I/0 MagSafe board. It is runs under the AirPort card and you must remove the left fan and Airport card to get to it. You will also need to disconnect about 5 different plugs, at least 2 from the Logic Board.
Score 3
Add a comment
Add your answer
mariogranados will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,265
