Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Questions View all
Won't boot on internal drive after battery replacement
I just changed the battery on my Macbook pro 13" and now when I start it up I just get a Os X Utilities page asking me to either restore from Backup, reinstall Os X or use disk utility.
The hard drive seems still to be working since I verified it with disk utility, bit it won't start up on it.
What shall i do?
Thanks for any tip!
Score 1
Add a comment
Chosen Solution
Well, do what it asks, run Disk Utilities and see if there's a problem.
Score 2
1 Comment:
Well I did and it said the drive is ok. But I still can't boot on it!
It still goes directly to the OS X utility page.
by
Add a comment
I could no longer boot to my newly installed Samsung SSD (replacing the original HDD) after changing the battery.
But the SSD would boot when connected externally via USB.
I discovered that the cable from the disk drive to the motherboard had been dislodged at the motherboard.
Once this was re-seated and tight, the SSD showed up again!
Add a comment
Add your answer
dschlock will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 326
