2
Score
deetex
81
Asked
Minimizing my MacBook Pro's heat
What can I do, other then keep the heatsinks clean and monitor Fan speeds, to keep my system's thermals down?
Dabbling a bit into games(Torchligh
I've cleaned out that mess Apple calls Thermal grease and used compressed air to clear out the heatsinks, but it seems to help only for a day or two, and a degree or so...
Edit Dec. 8, 2009:
I've considered purchasing a notebook stand/cooling assembly, but decided against it for mobility reasons.
My 'BookPro pretty much goes wherever I go, and that often means long train rides... I don't see myself hauling a piece of equipment along for the ride.
Additionally, from a design standpoint, the airflow of a cooling stand would fall on a flat surface, there's nothing there to promote heat-exchange... as the system's intakes, I believe, are alongside the keyboard.
3
Score
Ben Eisenman
53.5k
Answered
Accepted Answer
One option (treating the symptom, rather than the root of the problem) is to install Fan Control. With it, you can manually control the temp that your fans kick in, see fan information, etc.
I hope this helps!
0
Score
rj713
33.9k
Answered
0
Score
rdklinc
15.3k
Answered
0
Score
deetex
81
Answered
THe Memory cap for this system lies at 6Gb, but that 4Gb SO-DIMM is rather expensive. I already run Snow Leopard which took a full 2 degrees of the max back-then... but that's it.
SMCfanControl is currently running automatically at startup, and helps keep the heat down once it's there, if there's no real cure for the issue, I will let it slide, so long as that G86 chip doesn't go bad on me, it's no real threat to my health.
