Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328 Questions View all
Question Closed
After drop, screen has transparent grey bar, can I fix?
I dropped my mackbook air after which the screen displays a vertical transparent grey bar across most of the screen width and some flickering lines at the top and bottom. I can still see enough to use it but the grey bar etc.is inhibiting.
When the background is white there is no apparent interference although the colours are a bit washed out under the grey bar. The problem is awful when the background colour is grey with many flickering horizontal lines.
I have checked the connector to the screen and it appears to be locked correctly.
Do I need to replace the display?
Add a comment
Chosen Solution
Sorry to tell you your LCD screen has become damaged.
The driver chips have a bad solder joint or burn't and/or the flex circuit board that ties into the LCD has become dislodged from the fall.
In any case its' time for a new display. To verify this connect an external display to your system if the bars don't show up that verifies it.
Score 2
1 Comment:
Thanks Steffen and Dan. I have checked with an external display and that looks fine. So I have to replace the screen again having only just replaced it a few months ago. Doh! how clumsy am I. :o(
Again many thanks
by
Add a comment
Most Helpful Answer
Hi John,
It could be a software issue or a hardware problem. Check out this link.
My guess is that it is a hardware issue and the display got damaged. But check out the computer by connecting it to an external monitor first.
Steffen
Score 2
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,398
