Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Question Closed
iPhone stuck in recovery mode after power button repair
My power button was only working intermittently, so I followed the guide to replace the power button. There wasn't a detailed description of how the power button, power cable, and power button bracket should fit back together - and as it rather falls apart when disassembling I didn't see their original configuration. I wasn't sure if the swiveling silver bar on the power button has a special purpose related to the power cable?
I successfully got all tucked up again and finished the repair. Now my power button doesn't work at all, and worse, my iPhone is stuck in recovery mode when I plug it in.
I've connected it to iTunes to restore, but after update (iOS 7 was already installed) and going through the restore process, it still boots up in recovery mode. I tried twice, same result.
Any clues to a cable that didn't seat all the way or a part that might be damaged that would cause this?
Add a comment
Most Helpful Answer
To get out of recovery mode, download <a href=http://jaxov.com/2010/05/recboot-iphone-...> RecBoot</a>. It takes the iPhone out of recovery mode. For the power button, try reinstalling. If that doesn't help, make sure the cable is seated in the logic board correctly.
Score 1
Add a comment
No idea but I have the same issue :(.
Add a comment
Same issue for me. Any luck?
Add a comment
Try Tenorshare ReiBoot: http://www.any-data-recovery.com/product...
Features:
1. Very simple-Get iPhone into/out of recovery mode with one click
2. Free tool
3. Without the need of power or home button.
Add a comment
i have the same problem right now.
can anyone help please...
restoring from itunes or tinymbrela wont work..
Add a comment
Make sure that your iPhone is in recovery mode, not DFU mode.
http://www.android-recovery-transfer.com...
If it's in recovery mode, you can get it out of the mode by clicking the Restart button. If it's in DFU mode, you can try to exit DFU mode manually: press the Home and Power button at the same time for about 15 seconds, until you see the Apple logo appearing on the screen. Then release the buttons and your iPad will be back to normal.
Add a comment
I would say your suffering from pry damage if you took battery out and leavered a tool off the motherboard to pry battery up then you have knocked components off..
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,907
