0
Score
Avatar
Daniel
Asked
Can someone help me by telling me how to fix wi-fi card?
History
Got iPod used with not working wi-fi. I know for a fact it is either the card or the wire. I have tried restoring it three times and it still doesn't work.If anyone needs specific info just ask and i'll let you know.
Post Answer
0
Score
Avatar
markus weiher
21.4k
Answered
PermalinkHistory
here you can see the wi-fi chip in step 10 - but there is nothing you could do - there are no simple "cables"
the 2nd gen touch had always some issues with wifi
I wasn't saying there was a fix-all cable but what i was saying was that i heard of someone with the same problem and the answer was that there was a cable disconnected in his iPod that stopped his iPods wi-fi from working. Once he fixed that it stopped his problems. Are you absolutely, positively sure that it's the wi-fi card.
Daniel,
i'll get a few 2nd gen. touch today or tomorrow - then i will look at the wifi stuff to see what could be causing this problem
markus weiher,
0
Score
Avatar
barlowdo
279
Answered
PermalinkHistory
Can you see Wifi in the Settings or is it grayed out?
I bought a replacement wifi cable thinking it may solve my decreased signal strength. But I am disappointed to find that one side of the cable appears to be attached directly to the circuit board and there is no connector.
Maybe someone else knows how it is connected but to me it looks like it was done with a very expensive machine that has to place it exactly in one location to make all the very small tabs line up.
There is a small ribbon cable section that goes off parallel to the main cable that connects to the volume control but I don't think this slide connector being loose would impact the wifi.
There is also a small cable that does not come with the replacement wifi cable and is seen in step 10 of the tear down and the letters CE are just below the ribbon. I have no idea how this small ribbon is attached to the wifi cable.
If you have very limited connectivity it may be that the ribbon cable has pulled loose from the back of the iPod case.
In step 10 of the tear down you can see three tan colored rectangle sections with radiused corners. They are covered with what I will call "conductive glue". Underneath this "conductive glue" are copper pads. I believe these pads need to contact the metal case back for proper grounding. The "conductive glue" allows a electrical path to the ground plane. On yours this may have pulled loose.
I am calling it "conductive glue" in quotes because I do not know the proper name or where to buy it.
0
Score
Avatar
Sean McPhillips
Answered
PermalinkHistory
I am having a simialr problem. I cut the ribbon connecting the wifi card. Is there anyway to replace the ribbon or strip and connect it or am I sunk?
Saen McPhillips, if you need some help with that, you really should ask your own question. right now it appears as if you are answering a question that is a year old and the last response is almost a year old. So click on the link on the right hand side of this page, where it says "Ask a question" and give as much details as possible so the the great people on here can help you out. Good Luck
oldturkey03,
0
Score
Avatar
easydeepan
Answered
PermalinkHistory
if we are not capable of making an open service then I prefer taking ipod to a service center.
Try to use a hair dryer to blow over the WIFI area without opening it.There are very little chances to get solved if there is a cable leak issue.I am not sure how long this fix works!
Edited by
Add Your Answer
