Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
I need three different kinds of screw drivers to fully open?
I have the liberation kit which opens the first bottom two screws and quite a few inside but there are about 3 screws that just won't budge with either driver? These screws seem to be too big for the pentalobe but too small for the phillips. They are cross shaped; one gold-colored screw near the cellular antenna after removing the battery near the bottom and two towards the other on the top panel that covers the power and sensor cable.
I assume I have the Phillips #00 Screwdriver but these need a #000?
What do you guys suggest?
I recently "dipped" the bottom of my iphone 4 CDMA in soapy water. I read the article on what to do about that, I am just trying to open up my phone, clean it, and replace the battery to see if everything will work like before, since it can turn on when plugged in, make calls/text and has all the information.
Thanks!
Score 1
Add a comment
Chosen Solution
Here are the tools need to work on your iPhone:
Tools
iPhone 5-Point Pentalobe Screwdriver (if iPhone has external pentalobe screws)
iPhone SIM Card Eject Tool
Phillips #000 Screwdriver (if iPhone has external Phillips screws)
Plastic Opening Tools
2.5 mm Flathead Screwdriver
Spudger
Score 1
Add a comment
Yes, you need three different screw for iPhone.
Add a comment
Add your answer
Keira will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 210
