0
Score
Avatar
markus weiher
21.4k
Asked
MacBook won't wake up from Hibernation
History
I have a MacBook that won't wake up from hibernation mode.
i wanted to drain the battery and let the MacBook go all the way down.
(i needed some voltage informations from the "empty" battery)
removed the battery, made my "stuff" and tried to start the MacBook again - but nothing - it stays dead, i charged the battery in another MacBook, put it in the dead one and nothing.
tried to start it with the powercord & the battery, only with the powercord - but still nothing.
tried it without the topcase (to rule a topcase problem out)
it does not react in any way.
changed the dc-in board - nothing.
one thing i noticed - the magsafe connector does not show anything when plugged to the MacBook (tried several ones) - BUT, when i plug in the magsafe and press the power button, the magsafe connector starts to flash orange (very faint)
any suggestions what in could try ?
Is it hibernating or completely off?
remacberlin,
now - completely off
markus weiher,
Post Answer
2
Score
Avatar
mayer
121.8k
Answered
Accepted Answer
PermalinkHistory
As good a tech as you are, I'd start tracking it down with a voltmeter, starting at the mag port.
Agreed + Ralph
rj713,
thanks for the tip, i'll try that later (it's 5am - so later will be better)
markus weiher,
hi richard, i accepted your answer because it was the only way to start handling this issue
markus weiher,
Score
Avatar
Keely Arnett
13
Answered
PermalinkHistory
Try holding down the option key why you turn the power on. It should come up with which HD you want to boot from, may get you passed the hibernation mode.
nope - didn't change anything, still dead
markus weiher,
Score
Avatar
markus weiher
21.4k
Answered
PermalinkHistory
here we go again - first of all i want to thank richard for his suggestion - i teared it apart and found something - i have no idea how it happened
i think the pictures are pretty revealing i will get tomorrow something to hold my tiny jeweler magnifier (picters were taken with it and my nokia phone ;-) ) - and then i try to fix it
Edited by
We call that a toasted board ;-)
mayer,
and i call that a challenge ;-)
markus weiher,
0
Score
Avatar
rj713
33.9k
Answered
PermalinkHistory
markus have you tried reseting the SMU and PRAM? Ralph
http://support.apple.com/kb/HT3964
http://support.apple.com/kb/HT1379
Edited by
0
Score
Avatar
nick
12.3k
Answered
PermalinkHistory
You may just wanna get a new logicboard cause it be easier and by looking at the logicboard theres no other way but IF you wanna try harder stuff go ahead
Edited by
Why should there be no other way ??? at least i'll try it tomorrow - i've worked with smd parts for years - if it works - ok, if not - who cares - it's not mine ;-)
markus weiher,
The man wants a challenge--- I remember starting out we all did component level repair. No one would think of replacing a board--you found the faulty component and replaced it. Progress I guess. Ralph
rj713,
Add Your Answer
