Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Replaced full screen, digitizer works but no picture
Hi there,
Long story short... Broke the glass on my iPhone 4 and bought a replacement on Amazon for $20. I was skeptical but stay with me.
I work in a computer repair shop so I figured I was up to the task.
Did the whole repair and everything, and I've got no picture... not even a backlight. HOWEVER, the digitizer works because I can still unlock the phone without the display working (the phone makes the little unlock sound).
I plan to open it up again tomorrow and check connections but I figured I'd ask... could I have gotten a bad screen?
I've read where others have the backlight work but not the screen, but I don't have either... but the digitizer works and if I'm not mistaken, that was the smaller of the 2 cables that had to be fed back into the device.
Please advice.
Score -1
Add a comment
1 Answer
Chosen Solution
Soft reset the iphone by holding down the sleep/wake and home button until you see the apple logo. If that doesn't work, go back in and check your lcd cable connections by re-seating them and also inspect the receptacle on the logic board to ensure you didn't accidentally break a gold pin. If none of that works then it is possible you have a LCD that is DOA.
Usually, the LCD cable will pop up on re-assembly and can be easily overlooked.
If your old LCD worked, you can connect it back -- without removing the new screen, to verify that the new LCD is defective. I always simply disconnecting the old lcd cables, without removing the old LCD, and connecting up any new lcd just for quick testing. I believe iFixit and other companies sell an extended length testing cable just for this purpose.
Score 2
2 Comments:
Thank you for the detailed response. I performed a soft reset last night upon completion and I know no Apple logo appeared.
Once I get back from work today I will reopen the unit and confirm the LCD cable is in place. My last screen is pretty badly cracked, and I definitely added to the crack in its removal, but I can definitely pop it back in (as you suggested) to test.
I will follow up again this evening.
Cheers.
by
Just wanted to follow up and say that after taking it apart again, and reseating the LCD connector, followed by a soft reset, I was good to go!
I did accidentally not reconnect the cell antenna and found myself with no signal for about half an hour, but another 20 minutes later and I was good.
Cheers!
by
Add a comment
Add your answer
Ben will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,970
