Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 Questions View all
Replacing battery went wrong won't turn on, any ideas?
My macbook battery had been swinging from "condition normal" to "service battery" so I thought about checking the connections/cleaning it up and also to inspect it for swelling.
I opened up the macbook and took off the battery. Apart from a bit of dust it looked fine so I proceeded to connect it back in.
As soon as I finished I checked if it booted and it won't turn on.
The battery indicator lights do not light up, connecting the power adapter shows only a dim green light on the adapter.
I tried also powering it up with the battery disconnected but and with just the AC but it does not show any sign of life. The adapters's light keeps showing only a dim green.
I checked also the battery indicator flex cable and it looks fine. I also tried a SMC reset by disconnecting all power sources and pressing the power button 10s but to no avail.
So, is a macbook mid 2010 or recent able to boot without a battery? - If so I might need a new logic board - or does it need a battery to boot? - this means I might be able to get it back in order if I replace the battery.
Score -1
Add a comment
1 Answer
Most Helpful Answer
Try the SMC reset !
Remove all external devices from USB, connect power supply. Hold down shift + alt + power button for a couple seconds. Release and press power, maybe it´s fixed !
Colin P
Score 1
Add a comment
Add your answer
sergiojardim will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 2,288
