0
Score
Avatar
SergeantSpam
Asked
Trackpad not working after keyboard cleaning.
History
This morning I lightly wiped the keyboard, trackpad, and palm rest area with a sanitizing wipe - something I've done many times over the years.
My trackpad now does not work properly. The cursor skips across the screen in small steps when trying to use the trackpad, and will drift when left untouched.
I have tried resetting NVRAM (cmd opt p r) and removing the Finder preference files, but I get the same behavior - this is all I could find that was self-help related...
I removed the trackpad from the frame and inspected the connector cable and wiped all corners / edges of the frame and trackpad - still no go. Same results as before.
Keyboard works fine, as does an external mouse.
AppleCare is now expired (must be only a couple days outside of warranty)...
Before I spend $90 on a replacement trackpad, I'm looking for a way to confirm that the trackpad is indeed the issue.
Thanks.
Thank you Owen. Using a sheet of paper to wick moisture away / out of the crevices is a good idea. Even after 12 hours the trackpad was still acting up. I was not clear above, but when I mentioned wiping edges of the case and trackpad, that was with a soft dry cloth hoping to pull out any wetness. Interestingly (to me), there was no moisture / wetness to be seen or felt. When I got home I pulled the trackpad again and swapped it with my wife's MacBook thinking this would tell me what parts, for sure, I needed to order. Her trackpad works fine in my machine, and my trackpad works fine in her machine. Also of note, this process allowed me to adjust the click sensitivity on her machine, which has always driven me crazy. Thank you for the ideas.
SergeantSpam,
Post Answer
Score
Avatar
Owen Cunneely
4.2k
Answered
PermalinkHistory
How long have you waited since you cleaned it? I have this same issue when I wipe my computer down with water or any other computer product. The issues is that excess water gets along the sides of the trackpad, and similar to using your phone underwater, it thinks you are constantly touching the trackpad in every corner. I usually let the trackpad try out, but somethings it helps if you take a piece of paper, stick the edge in between the trackpad and the palm rest, and run it around the sides of the trackpad gently. You might see the paper gets wet. If it does get wet, just use another corner and go around again. This should work. If the problem still occurs, then you might want to take out your battery and see if there is any water under the trackpad. If nothing works, let it sit for a day or two, that normally will fix the problem. In the unlikely case that you did damage your trackpad, you may need to replace it. I have had this same issue though on MacBooks from 2006, to MacBook Pros from 2013, and either drying the sides with paper, or letting it sit always works.
Hope this Helps
Edited by: Owen Cunneely ( )
0
Score
Avatar
Ilija Milosavljevic
Answered
PermalinkHistory
I also have the same issue, i don't get it! I've cleaned it dozen times already.
I noticed that track pad goes a bit grazy, but never like this and never for this long
What should i do?! :S
0
Score
Avatar
Maria CarpenterYanga
Answered
PermalinkHistory
Use rubbing alcohol to clean it from now on. Dries instantly with no issues!
Add Your Answer
Today: 13
This Week: 59
This Month: 442
All Time: 4,126
